I am trying to run the crazyflie via python script using the send_hover_setpoint function to move the drone. Most of the time everything works. However, there are occasions where I run the code and the drone beeps a few times and then either does nothing or ascends very quickly until it crashes in the ceiling. I have tested 2 drones and this happens with both of them. I don't think this is a problem with the code because I simply modified the example code. Has this happened before, and is there a fix for this?
Thank you
Crazyflie 2 beeps and then flies straight up until it crashes
Re: Crazyflie 2 beeps and then flies straight up until it crashes
What version of the firmware are you using?
I set everything up on Monday, so I assume that would be the latest version
I think everything is okay now, the problem was with the crazyRadio, as it would disconnect sometimes.
