I am trying to control a ground vehicle with accessories in a similar manner as evoggy's crazycar project, sending data over UART to an arduino connected to various higher current drivers. At this point, the crazyflie is being used as a great rxtx solution using crtp!
My code has evolved from evoggy's crazycar.c on hackster: https://www.hackster.io/evoggy/crazycar-3c14b6
I looked at the following c and header files:
#include "FreeRTOS.h"
#include "timers.h"
#include "uart2.h"
#include "debug.h"
#include "log.h"
as well as log.c, crtp, examined
logGetVarIDI also checked these wiki pages:
https://wiki.bitcraze.io/projects:crazyflie:crtp
https://wiki.bitcraze.io/projects:crazy ... tp:console
https://wiki.bitcraze.io/doc:crazyflie:crtp:log
and some others
Based on the analysis, I think I can define a "yaw" and "thrust" (this looks to be scaled differently) and get some results similar to this part of the code in crazycar.c:
line 107:
static void crazycarDeckInit(DeckInfo *info)
logIdRoll = logGetVarId("ctrltarget", "roll");
logIdPitch = logGetVarId("ctrltarget", "pitch");
But, what would the buttons be called? How do I figure out the other strings to pass to the `logGetVarId`? I expect binary/boolean output, but don't know where to start mapping this controller or really, crazyflie log values that are actuated by input on the controller.
Edit: In case not clear, I am just trying to figure out the other log variable names for buttons or where to find this information in the code.
It also appears what evoggy did might not be the best way to do this, but he wanted a quick hack, because uart2SendData is for large debug information. However, I have not seen any problems so far, so I am ok with proceeding this way, but any further improvement is welcome!
Edit 2: Thinking about this some more, I realized the log variables I am targeting respond to events, so I will have to map my desired buttons to something in the cfclient, and then need the log variable name of the function, such as alt 1, 2, assisted control, kill switch, or mux switch (What does this mux do?) as far as I can tell. Still don't know where valid strings are found in the code though.
Edit 3: I searched the forum for 'evoggy', and see his stuff on hackster, but I thought he was a member of the Bitcraze team? Perhaps I was mistaken, I don't expect you guys to support/dig into code that is not yours.
