I'm trying to debug a crazyflie 2.0 (STM32F4) with a J-link EDU and after some iterations of flashing it started to keep giving me the following output. Right now only one blue LED (M2) is lit and when I tried to enter the bootloader by keep pressing the power button, only that blue LED keeps blinking, instead of two. I tried erasing the ROM with J-Link but couldn't see any difference. As far as I remember, the only change I did was just related to the stabilizerTask. Any ideas?
Update: I tried reflashing the STM32F4 firmware using the DFU mode, but still only one blue light is lit.
bitcraze@bitcraze-vm:~/projects/crazyflie-firmware$ make flash
openocd -d2 -f interface/jlink.cfg -c "transport select swd" -f target/stm32f4x.cfg -c init -c targets -c "reset halt" \
-c "flash write_image erase cf2.bin 0x8004000 bin" \
-c "verify_image cf2.bin 0x8004000 bin" -c "reset run" -c shutdown
GNU ARM Eclipse 32-bits Open On-Chip Debugger 0.9.0-00073-gdd34716-dirty (2015-05-19-09:59)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
Info : JLink SWD mode enabled
swd
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
cortex_m reset_config sysresetreq
Info : J-Link V10 compiled Apr 20 2018 16:47:09
Info : J-Link caps 0xb9ff7bbf
Info : J-Link hw version 101000
Info : J-Link hw type J-Link
Info : J-Link max mem block 14456
Info : J-Link configuration
Info : USB-Address: 0x0
Info : Kickstart power on JTAG-pin 19: 0xffffffff
Info : Vref = 3.25 TCK = 0 TDI = 0 TDO = 0 TMS = 0 SRST = 1 TRST = 1
Info : J-Link JTAG Interface ready
Info : clock speed 2000 kHz
Info : SWD IDCODE 0x2ba01477
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
TargetName Type Endian TapName State
0* stm32f4x.cpu cortex_m little stm32f4x.cpu halted
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x00010100 msp: 0x464c457c
auto erase enabled
Info : device id = 0x10076413
Info : flash size = 1024kbytes
wrote 376832 bytes from file cf2.bin in 9.132847s (40.294 KiB/s)
verified 342072 bytes in 2.933342s (113.882 KiB/s)
Error: stm32f4x.cpu -- clearing lockup after double fault
target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x00000003 pc: 00000000 msp: 0x464c4558
Polling target stm32f4x.cpu failed, trying to reexamine
shutdown command invoked
