Adding an extra DDECK_FORCE to config.mk [SOLVED]
Jens_Lee
Re: Adding an extra DDECK_FORCE to config.mk [SOLVED]
Post by Jens_Lee »
arix wrote: Tue Mar 27, 2018 1:13 pm hello
I also want solve extra force deck, but i can't understand what you say. can you tell me the detial information about copy DECK_FORCE and pasting DECK_FORCE1.
Hi arix
Right now deck_info.c has the option for 1 forced deck or DECK_FORCE. It checks if DECK_FORCE have been defined in in config.mk and if it has, it looks for a corresponding driver. If succesful, and the ammount of accumulated decks are less then DECK_MAX_COUNT, it adds the new deck and driver to the build.
The "Hack" is simply taking everywhere DECK_FORCE occurs and duplicate those functions, but with a new name, for example DECK_FORCE1.
I have attached my version of that solution, I can't see why it wouldn't work in your firmware, but YMMW.
 *    ||          ____  _ __
 * +------+      / __ )(_) /_______________ _____  ___
 * | 0xBC |     / __  / / __/ ___/ ___/ __ `/_  / / _ \
 * +------+    / /_/ / / /_/ /__/ /  / /_/ / / /_/  __/
 *  ||  ||    /_____/_/\__/\___/_/   \__,_/ /___/\___/
 * Crazyflie control firmware
 * Copyright (C) 2015 Bitcraze AB
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, in version 3.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program. If not, see <http://www.gnu.org/licenses/>.
 * deck_ow.c - Functions to decode the decks oneWire memory content
#include <stdlib.h>
#include <stdbool.h>
#include <string.h>
#define DEBUG_MODULE "DECK_INFO"
#include "deck.h"
#include "ow.h"
#include "crc.h"
#include "debug.h"
#ifdef DEBUG
  #define DECK_INFO_DBG_PRINT(fmt, ...)  DEBUG_PRINT(fmt, ## __VA_ARGS__)
#else
  #define DECK_INFO_DBG_PRINT(...)
#endif
static int count = 0;
static DeckInfo deckInfos[DECK_MAX_COUNT];
static void enumerateDecks(void);
static void checkPeriphAndGpioConflicts(void);
static void scanRequiredSystemProperties(void);
static StateEstimatorType requiredEstimator = anyEstimator;
static bool registerRequiredEstimator(StateEstimatorType estimator);
static bool requiredLowInterferenceRadioMode = false;
#ifndef DECK_FORCE
#define DECK_FORCE
#endif
#ifndef DECK_FORCE1
#define DECK_FORCE1
#endif
#define xstr(s) str(s)
#define str(s) #s
static char* deck_force = xstr(DECK_FORCE);
static char* deck_force1 = xstr(DECK_FORCE1);
void deckInfoInit()
  static bool isInit = false;
  if (isInit) return;
  enumerateDecks();
  checkPeriphAndGpioConflicts();
  scanRequiredSystemProperties();
  isInit = true;
int deckCount(void)
  return count;
DeckInfo * deckInfo(int i)
  if (i<count) {
    return &deckInfos[i];
  return NULL;
// Dummy driver for decks that do not have a driver implemented
static const DeckDriver dummyDriver;
static const DeckDriver * findDriver(DeckInfo *deck)
  char name[30];
  const DeckDriver *driver = &dummyDriver;
  deckTlvGetString(&deck->tlv, DECK_INFO_NAME, name, 30);
  if (deck->vid) {
    driver = deckFindDriverByVidPid(deck->vid, deck->pid);
  } else if (strlen(name)>0) {
    driver = deckFindDriverByName(name);
  if (driver == NULL)
  return driver;
void printDeckInfo(DeckInfo *info)
  char name[30] = "NoName";
  char rev[10] = "NoRev";
  if (deckTlvHasElement(&info->tlv, DECK_INFO_NAME)) {
    deckTlvGetString(&info->tlv, DECK_INFO_NAME, name, 30);
  if (deckTlvHasElement(&info->tlv, DECK_INFO_REVISION)) {
    deckTlvGetString(&info->tlv, DECK_INFO_REVISION, rev, 10);
  DECK_INFO_DBG_PRINT("Deck %02x:%02x %s (Rev. %s)\n", info->vid, info->pid, name, rev);
  DECK_INFO_DBG_PRINT("Used pin: %08x\n", (unsigned int)info->usedPins);
  if (info->driver == &dummyDriver) {
    DEBUG_PRINT("Warning! No driver found for deck.\n");
  } else {
    DECK_INFO_DBG_PRINT("Driver implements: [ %s%s]\n",
                        info->driver->init?"init ":"", info->driver->test?"test ":"");
static bool infoDecode(DeckInfo * info)
  uint8_t crcHeader;
  uint8_t crcTlv;
  if (info->header != DECK_INFO_HEADER_ID) {
    DEBUG_PRINT("Memory error: wrong header ID\n");
    return false;
  crcHeader = crcSlow(info->raw, DECK_INFO_HEADER_SIZE);
  if(info->crc != crcHeader) {
    DEBUG_PRINT("Memory error: incorrect header CRC\n");
    return false;
  if(info->raw[DECK_INFO_TLV_VERSION_POS] != DECK_INFO_TLV_VERSION) {
    DEBUG_PRINT("Memory error: incorrect TLV version\n");
    return false;
  crcTlv = crcSlow(&info->raw[DECK_INFO_TLV_VERSION_POS], info->raw[DECK_INFO_TLV_LENGTH_POS]+2);
  if(crcTlv != info->raw[DECK_INFO_TLV_DATA_POS + info->raw[DECK_INFO_TLV_LENGTH_POS]]) {
    DEBUG_PRINT("Memory error: incorrect TLV CRC %x!=%x\n", (unsigned int)crcTlv,
                info->raw[DECK_INFO_TLV_DATA_POS + info->raw[DECK_INFO_TLV_LENGTH_POS]]);
    return false;
  info->tlv.data = &info->raw[DECK_INFO_TLV_DATA_POS];
  info->tlv.length = info->raw[DECK_INFO_TLV_LENGTH_POS];
  return true;
  uint8_t nDecks = 0;
  int i;
  bool noError = true;
  owInit();
  if (owScan(&nDecks))
    DEBUG_PRINT("Found %d deck memor%s.\n", nDecks, nDecks>1?"ies":"y");
  } else {
    DEBUG_PRINT("Error scanning for deck memories, "
                "no deck drivers will be initialised\n");
    nDecks = 0;
  for (i = 0; i < nDecks; i++)
    DECK_INFO_DBG_PRINT("Enumerating deck %i\n", i);
    if (owRead(i, 0, sizeof(deckInfos[0].raw), (uint8_t *)&deckInfos[i]))
      if (infoDecode(&deckInfos[i]))
        deckInfos[i].driver = findDriver(&deckInfos[i]);
        printDeckInfo(&deckInfos[i]);
      } else {
#ifdef DEBUG
        DEBUG_PRINT("Deck %i has corrupt OW memory. "
                    "Ignoring the deck in DEBUG mode.\n", i);
        deckInfos[i].driver = &dummyDriver;
#else
                    "No driver will be initialized!\n", i);
        noError = false;
#endif
    else
      DEBUG_PRINT("Reading deck nr:%d [FAILED]. "
      noError = false;
  // Add build-forced driver
  if (strlen(deck_force) > 0) {
    const DeckDriver *driver = deckFindDriverByName(deck_force);
    if (!driver) {
      DEBUG_PRINT("WARNING: compile-time forced driver %s not found\n", deck_force);
    } else if (driver->init) {
      if (nDecks <= DECK_MAX_COUNT)
        nDecks++;
        deckInfos[nDecks - 1].driver = driver;
        DEBUG_PRINT("compile-time forced driver %s added\n", deck_force);
      } else {
        DEBUG_PRINT("WARNING: No room for compile-time forced driver\n");
  if (strlen(deck_force1) > 0) {
    const DeckDriver *driver = deckFindDriverByName(deck_force1);
    if (!driver) {
      DEBUG_PRINT("WARNING: compile-time forced driver %s not found\n", deck_force1);
        nDecks++;
        DEBUG_PRINT("compile-time forced driver %s added\n", deck_force1);
      } else {
  if (noError) {
    count = nDecks;
  return;
  uint32_t usedPeriph = 0;
  uint32_t usedGpio = 0;
  for (int i = 0; i < count; i++)
    if (usedPeriph & deckInfos[i].driver->usedPeriph) {
      DEBUG_PRINT("ERROR: Driver Periph usage conflicts with a "
                  "previously enumerated deck driver. No decks will be "
                  "initialized!\n");
      noError = false;
    if (usedGpio & deckInfos[i].driver->usedGpio) {
      DEBUG_PRINT("ERROR: Driver Gpio usage conflicts with a "
                  "initialized!\n");
      noError = false;
    usedPeriph |= deckInfos[i].driver->usedPeriph;
    usedGpio |= deckInfos[i].driver->usedGpio;
  if (!noError) {
    count = 0;
/****** Key/value area handling ********/
static int findType(TlvArea *tlv, int type) {
  int pos = 0;
  while (pos < tlv->length) {
    if (tlv->data[pos] == type) {
      return pos;
    } else {
      pos += tlv->data[pos+1]+2;
  return -1;
bool deckTlvHasElement(TlvArea *tlv, int type) {
  return findType(tlv, type) >= 0;
int deckTlvGetString(TlvArea *tlv, int type, char *string, int length) {
  int pos = findType(tlv, type);
  int strlength = 0;
  if (pos >= 0) {
    strlength = tlv->data[pos+1];
    if (strlength > (length-1)) {
      strlength = length-1;
    memcpy(string, &tlv->data[pos+2], strlength);
    string[strlength] = '\0';
    return strlength;
  } else {
    string[0] = '\0';
    return -1;
char* deckTlvGetBuffer(TlvArea *tlv, int type, int *length) {
  if (pos >= 0) {
    *length = tlv->data[pos+1];
    return (char*) &tlv->data[pos+2];
  return NULL;
void deckTlvGetTlv(TlvArea *tlv, int type, TlvArea *output) {
  output->length = 0;
  output->data = (uint8_t *)deckTlvGetBuffer(tlv, type, &output->length);
  bool isError = false;
    isError = isError || registerRequiredEstimator(deckInfos[i].driver->requiredEstimator);
    requiredLowInterferenceRadioMode |= deckInfos[i].driver->requiredLowInterferenceRadioMode;
  if (isError) {
    count = 0;
  if (anyEstimator != estimator)
    if (anyEstimator == requiredEstimator)
      requiredEstimator = estimator;
    else
      if (requiredEstimator != estimator) {
        isError = true;
        DEBUG_PRINT("WARNING: Two decks require different estimators\n");
  return isError;
StateEstimatorType deckGetRequiredEstimator()
  return requiredEstimator;
bool deckGetRequiredLowInterferenceRadioMode()
  return requiredLowInterferenceRadioMode;
/code]
arix
Post by arix »
Jens_Lee wrote: Wed Mar 28, 2018 9:20 am
Hi arix
 *    ||          ____  _ __
#include <stdlib.h>
#include <string.h>
#include "deck.h"
#include "ow.h"
#include "crc.h"
#include "debug.h"
#ifdef DEBUG
#else
#endif
#ifndef DECK_FORCE
#define DECK_FORCE
#endif
#ifndef DECK_FORCE1
#define DECK_FORCE1
#endif
#define str(s) #s
void deckInfoInit()
  if (isInit) return;
  enumerateDecks();
  isInit = true;
int deckCount(void)
  return count;
  if (i<count) {
  return NULL;
  char name[30];
  if (deck->vid) {
  if (driver == NULL)
  return driver;
  } else {
  uint8_t crcHeader;
  uint8_t crcTlv;
    return false;
    return false;
    return false;
    return false;
  return true;
  uint8_t nDecks = 0;
  int i;
  owInit();
  } else {
    nDecks = 0;
      } else {
#ifdef DEBUG
#else
        noError = false;
#endif
    else
      noError = false;
    if (!driver) {
        nDecks++;
      } else {
    if (!driver) {
        nDecks++;
      } else {
  if (noError) {
    count = nDecks;
  return;
                  "initialized!\n");
      noError = false;
                  "initialized!\n");
      noError = false;
  if (!noError) {
    count = 0;
  int pos = 0;
      return pos;
    } else {
  return -1;
  int strlength = 0;
  if (pos >= 0) {
    return strlength;
  } else {
    string[0] = '\0';
    return -1;
  if (pos >= 0) {
  return NULL;
  output->length = 0;
  if (isError) {
    count = 0;
    else
        isError = true;
  return isError;
/code]
[/quote]
Thank you ! I have solved it with you help!
