Delay update log(?)
cha8138
Delay update log(?)
Post by cha8138 »
Hi.
Currently, I am working on registering values on log and receiving data using python3 library.
I tried to update integer data(65 to 90) in order and monitored the received data with Crazyflie PC client.
But the received data wasn't matching with the data I updated.
Here is my code and result.
#define DEBUG_MODULE "uartDeck"
#include "debug.h"
#include "deck.h"
#include "deck_core.h"
#include "log.h"
#include "FreeRTOS.h"
#include "stdbool.h"
#include "timers.h"
#include "uart1.h"
#include "console.h"
#include "task.h"
//static xTimerHandle timer;
char cData;
char i=65;
void receiveData(void *param)
	//DEBUG_PRINT("Running Uart:\n");
	while(1)
		cData=i;
		i++;
		if(i==90)
			i=65;
static void uartCommInit(DeckInfo *info)
  uart1Init(9600);
  xTaskCreate(receiveData, "commUart",configMINIMAL_STACK_SIZE, NULL, /*priority*/1, NULL);
  DEBUG_PRINT("Inited uartComm deck.\n");
static const DeckDriver uartCommDriver = {
  .name = "commUart",
  .usedGpio = 0,
  .init = uartCommInit,
DECK_DRIVER(uartCommDriver);
LOG_GROUP_START(myUartData)
LOG_ADD(LOG_UINT8, character, &cData)
LOG_GROUP_STOP(myUartData)
Is there any problem in my code? or Is there any limit on the rate of updating data?
Thank you.
Re: Delay update log(?)
Yes the data update is limited to the specified sample rate and currently limited to every 10ms. So you are seeing an aliasing effect.
cha8138
Post by cha8138 »
tobias wrote: Fri Aug 18, 2017 12:15 pm Yes the data update is limited to the specified sample rate and currently limited to every 10ms. So you are seeing an aliasing effect.
Oh, I see. Thank you. :D
