Error when I want to flash the firmware to Crazyflie
matthieuouy
Post by matthieuouy » Wed Jul 26, 2017 1:47 pm
I'm new in this forum: I'd just bought my drone a month ago.
Yesterday, I started to learn how to modify the SourceCode on the VirtualMachine with the tutorial on the website. I followed all the steps and when I wanted to flash the code, there was an error:
[Errno2] No such file or directory: 'cf2.bin'
Can someone help me please? :)
Thanks a lot
Matthieu
Re: Error when I want to flash the firmware to Crazyflie
Post by arnaud » Thu Jul 27, 2017 8:25 am
Hi, what command where you running when this error appeared? I assume you where running "Flash using radio"? If so, you should first build the firmware with "make CLOAD", this will generate 'cf2.bin' (assuming the compilation completes without error ;).
percy.jaiswal
Post by percy.jaiswal » Wed Sep 19, 2018 6:14 am
Thanks Arnaud. Even I was facing this problem and your suggestion helped solve it. I think this step should be mentioned in "Programming the Crazyflie" tutorial under "Build the source code" section.
