Hello, I'm trying to control height of flie by PID controlling the z-ranger value
using the crazyflie ROS driver ( https://github.com/whoenig/crazyflie_ros )
However, It seems like that range.zrange value is logged and subscribed with period 100ms, i.e. 10Hz
It seems to be insufficient for control. How can I adjust the period of z range sampling? I guess the sampling rate spec of VL53L0X must not be 10Hz, it's too low
[SOLVED] z range sensor sampling period
Re: z range sensor sampling period
Are you trying to do the PID regulation on the computer? The delay might be a problem.
I can't remember the fastest time the sensor can sample but it depends on the surface and environment. Think it is around every 30ms.
Yes. through PID control. Then how is the height hold mode in cfclient implemented? In the same environment, client works.tobias wrote:Are you trying to do the PID regulation on the computer? The delay might be a problem.
In the sensor spec, it says it supports up to 50hz in "fast mode". I can't figure out what it is. 10hz is too poor
http://www.st.com/content/ccc/resource/ ... 279088.pdf
I found the sensor programming API, and now looking over it
now I looked it over and again look over the firmware source code. Is it right that already firmware is coded to get the measurement as fast as it can?
I found my crazyflie ROS driver subscribes /range at period 100ms regardeless of surface and environments, and tryna find out why
now I figured it out. In crazyflie_server.cpp, logblock frequency was set by start(frequency). Thanks
Re: [SOLVED] z range sensor sampling period
Does it mean that the log frequency was wrong? What change did you have to do to make it work?
The code as it is now is setup to take measurements with the vl53 as fast as possible.
@y.choi
How did you get the zrange value from CF firmware via ROS package by whoing?
You can setup log block with the ROS package so you can setup a log block that gets the zRanger range and publish it as a topic at regular interval.
