[SOLVED] Cannot generate the PWM signal to the breakout board of the STM32F405 microcontroller
Re: Cannot generate the PWM signal to the breakout board of the STM32F405 microcontroller
Great! Would be nice to know what you fixed to get it to work.
Here is the code I use:
What I have changed is:
- I don't know why the macros or the names like TIM10, GPIOB, GPIO_Pin_8 .... have the error "Symbol .... could not be resolved, return 0" so I replace them all with the address in the libraries. Maybe some problems of Eclipse. This will remove all the bug signs in some lines as I posted at the beginning of the thread.
- I just deleted the old Virtual Machine Crazyflie, readded a new VM, clone all the projects and add my PWM deck in the project like the tutorials. The compilation and flashing work well then. I don't know why I can only flash once. If I want to reflash again, i have to delete the VM and readd again.
#include "deck.h"
#include "debug.h"
/* ST includes */
#include "stm32f4xx.h"
#include "stm32f4xx_gpio.h"
#include "stm32f4xx_rcc.h"
#include "stm32f4xx_tim.h"
/*Predefined macros*/
#define IR_TX_CARRIER_FREQ 56000
#define IR_TX_CARRIER_PWM_PERIOD (SystemCoreClock/IR_TX_CARRIER_FREQ)
#define IR_TX_DELAY_PRESCALER (84-1)
#define ENABLE 1
#define IR_TX_CARRIER_TIMER TIM10
#define IR_TX_CARRIER_TIMER_RCC RCC_APB2Periph_TIM10
#define IR_TX_CARRIER_TIMER_CH_Init TIM_OC1Init
#define IR_TX_CARRIER_TIMER_CH_PreloadConfig TIM_OC1PreloadConfig
#define IR_TX_CARRIER_TIMER_CH_SetCompare TIM_SetCompare1
#define IR_TX_CARRIER_RCC RCC_AHB1Periph_GPIOB
#define IR_TX_CARRIER_PORT GPIOB
#define IR_TX_CARRIER_PIN GPIO_Pin_8
void pwmInit(DeckInfo *info)
DEBUG_PRINT("PWM Inited.\n");
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(0x00000002, ENABLE);
RCC_APB2PeriphClockCmd(0x00020000, ENABLE);
// Configure the GPIO for the timer output
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Pin = 0x0100;
GPIO_Init(((GPIO_TypeDef *) ((0x40000000 + 0x00020000) + 0x0400)), &GPIO_InitStructure);
GPIO_PinAFConfig(((GPIO_TypeDef *) ((0x40000000 + 0x00020000) + 0x0400)), 0x08, 0x03);
// Time base configuration
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 9881;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = (0x0000);
TIM_TimeBaseInit(((TIM_TypeDef *) ((0x40000000 + 0x00010000) + 0x4400)), &TIM_TimeBaseStructure);
// PWM channel configuration
TIM_OCStructInit(&TIM_OCInitStructure);
TIM_OCInitStructure.TIM_OCMode = 0x0060;
TIM_OCInitStructure.TIM_OutputState = 0x0001;
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_OCInitStructure.TIM_OCPolarity = 0x0000;
//TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
// Configure Output Compare for PWM
IR_TX_CARRIER_TIMER_CH_Init(((TIM_TypeDef *) ((0x40000000 + 0x00010000) + 0x4400)), &TIM_OCInitStructure);
IR_TX_CARRIER_TIMER_CH_PreloadConfig(((TIM_TypeDef *) ((0x40000000 + 0x00010000) + 0x4400)), 0x0008);
TIM_ARRPreloadConfig(((TIM_TypeDef *) ((0x40000000 + 0x00010000) + 0x4400)), 1);
TIM_Cmd(((TIM_TypeDef *) ((0x40000000 + 0x00010000) + 0x4400)), ENABLE);
((TIM_TypeDef *) ((0x40000000 + 0x00010000) + 0x4400))->CCR1 = 50*(9881/100);
bool pwmTest()
DEBUG_PRINT("PWM initlized successfully. \n");
return 1;
const DeckDriver pwm_ir = {
.vid = 0,
.pid = 0,
//.usedPeriph = DECK_USING_TIMER10,
//.usedGpio = DECK_USING_IO_1,
.name = "myPWM",
.init = pwmInit,
.test = pwmTest,
DECK_DRIVER(pwm_ir);
Re: [SOLVED] Cannot generate the PWM signal to the breakout board of the STM32F405 microcontroller
I aslo think it would be nice if you can list all the name of the free peripherals that still can be used for extension. By this way, we will not touch the peripherals that are already used for the basic function of the Crazyflie.
I think eclipse is not configured the right way that is why you get the warnings from the macros. I would strongly advice to use the macros anyway as the code becomes hard to read without them.
Yes I agree but something that might be hard to maintain and keep updated. Could be worth a try though. I tend to use the search function to find what is used. So if I what to know what timers are used I search for "TIM" to get all timers in the code.By this way, we will not touch the peripherals that are already used for the basic function of the Crazyflie.
In your code, can you make the PWM stop, go slower or faster? Sorry I had no clue how to interpret this code(seems so complicated)?
Thanks
Thanks
In the code copy-pasted above IR_TX_CARRIER_PWM_PERIOD and IR_TX_DELAY_PRESCALER should set the period of the PWM. These are pretty low level controls so I suggest you look at the STM32F405 reference manual to familiarise yourself with the timer you plan to use.
