I think it would be fun to add optical devices such as ANDS3080 to CF2 .
how to do make CF work properly with ADNS3080?
What should I do?
Has anyone added optical flow to the CF2?
Re: Has anyone added optical flow to the CF2?
We are currently working on adding an optical flow sensor to the Crazyflie, see our latest blog post: https://www.bitcraze.io/2017/06/icra-2017/.
If you want to add a new sensor to the Crazyflie you will have to attach it to the deck port and make a deck driver for it. The wiki contains more information about the deck connector pinout (https://wiki.bitcraze.io/projects:crazy ... ort_pinout) and software API (https://wiki.bitcraze.io/doc:crazyflie: ... mware:deck)
