crazyflie task priorities
wenlong
Post by wenlong »
In the file config.h, task priorities were set. but some tasks had the same priority such as STABILIZER_TASK_PRI was 4 and so the SENSORS_TASK_PRI, why did not set different priority, for example, the STABILIZER_TASK_PRI was 5 and SENSORS_TASK_PRI was 4?
Re: crazyflie task priorities
FreeRTOS allows us to have multiple tasks set with the same priority, in that case the tasks will be scheduled in round-robin.
Stabilizer and sensor tasks share the highest priority but there is no preference as of which one is more critical: each must be served regularity in order to fly, this is why they ended-up on the same priority level.
As a side note: adding priority level in FreeRTOS adds a bit of RAM consumption so it it was good for Crazyflie 1.0 to limit the number of priority level.
wenlong
Post by wenlong »
Thanks arnaud for your such clear answer!
