The map between voltage and thrust in crazyflie firmware
silva
Post by silva »
In which part of the firmware code, could i find the map between the battery voltage and the thrust value. thanks :)
Re: The map between voltage and thrust in crazyflie firmware
There is a thrust battery compensation in the motor driver: https://github.com/bitcraze/crazyflie-f ... ors.c#L211.
silva
Post by silva »
Hi Arnaud,
Many thanks!
