blocking user inputs and sending commands
Posted: Thu Apr 20, 2017 3:24 pm
I'm a student working on a group project. I have tried to become familiar with the developpement of the python client but some points are still dark to me.
Our first goal is to develop a function that allows the drone to safely land. For that, we have created a button in a new tab to activate the function even if we plan to trigger the landing from the controller in the near future.
The idea is :
- create a new configuration to retrieve acc.z and stabilizer.thrust.
- We block user inputs from the controller.
- everytime the cf sends back data, we analyse the acc.z to see if we're falling down and if so, we try to push the drone up
- Once we're not falling anymore, we decrease the thrust a bit to land slowly.
Logs are stacked everytime they are received on a list.
The problem is : I am not really sure to understand the interactions between the controller, the client and the drone. Is there a master process that centralize the commands sent or any process can send its command to the drone ? Am I sending commands correctly to the drone ? I tried to take inspiration from ramp.py, and flyTab.
Here is my code, (I have removed some methods to make it shorter for the post clarity)
Just for information, what is the difference between a param and the incomming log (as there are two different callbacks) ?
Thanks in advance for your help !
The idea is :
class TakeOffTab(Tab, take_off_tab_class):
"""Tab to do an automatic take off, hold an altitude and emergency landing"""
_connected_signal = pyqtSignal(str)
_disconnected_signal = pyqtSignal(str)
_log_data_signal = pyqtSignal(int, object, object)
_log_error_signal = pyqtSignal(object, str)
_param_updated_signal = pyqtSignal(str, str)
_start_emergency_landing_signal = pyqtSignal(bool)
_current_log = None
_log_stack = []
def __init__(self, tabWidget, helper, *args):
super(TakeOffTab, self).__init__(*args)
self.setupUi(self)
self.i = 0
self.tabName = "Take off"
self.menuName = "Take off Tab"
self.tabWidget = tabWidget
self._helper = helper
#this boolean indicates if the drone is currently doing an emergncy landing
self.in_emergency = False
self.emergency_phase = 0
# Always wrap callbacks from Crazyflie API though QT Signal/Slots
# to avoid manipulating the UI when rendering it
self._connected_signal.connect(self._connected)
self._disconnected_signal.connect(self._disconnected)
self._log_data_signal.connect(self._log_data_received)
self._param_updated_signal.connect(self._param_updated)
self._start_emergency_landing_signal.connect(self._start_emergency_landing)
# Connect the Crazyflie API callbacks to the signals
self._helper.cf.connected.add_callback(
self._connected_signal.emit)
self._helper.cf.disconnected.add_callback(
self._disconnected_signal.emit)
self._helper.inputDeviceReader.emergency_stop_updated.add_callback(
self._start_emergency_landing_signal.emit)
self._takeOffBtn.clicked.connect(self._log_estimated_z)
self._holdAltitudeBtn.clicked.connect(lambda enabled:
self._helper.cf.param.set_value("flightmode.althold", str(enabled)))
self._helper.cf.param.add_update_callback(group="alt", name="enable", cb=self._param_updated_signal.emit)
self._emergencyBtn.clicked.connect(self._start_emergency_landing)
def _connected(self, link_uri):
"""Callback when the Crazyflie has been connected"""
logger.debug("Crazyflie connected to {}".format(link_uri))
self.connectionLbl.setText("connected !")
self._log_stabilizer()
self.i+=1
self.dataLbl.setText(str(self.i))
def _log_stabilizer(self):
# The definition of the logconfig can be made before connecting
self._current_log = LogConfig(name='Stabilizer', period_in_ms=100)
self._current_log.add_variable('stabilizer.roll', 'float')
self._current_log.add_variable('stabilizer.yaw', 'float')
self._current_log.add_variable("stabilizer.yaw", "float")
self._current_log.add_variable("stabilizer.thrust", "uint16_t")
# Adding the configuration cannot be done until a Crazyflie is
# connected, since we need to check that the variables we
# would like to log are in the TOC.
self._helper.cf.log.add_config(self._current_log)
if self._current_log.valid:
#then we set the callbacks
self._current_log.data_received_cb.add_callback(self._log_data_signal.emit)
self._current_log.start()
def _start_emergency_landing(self):
#if we're already doing the emergency landing, we dismiss the click
if self.in_emergency:
return
else:
# The definition of the acceleration config
self.emergency_phase = 1
self._current_log = LogConfig(name='Emergency', period_in_ms=50)
self._current_log.add_variable('acc.z', 'float')
self._current_log.add_variable('stabilizer.thrust', 'uint16_t')
self.targetThrust.setEnabled(not enabled)
def _emergency_treatment(self):
# 1 is the phase where we check if we're falling and if so, we thrust up to stop it
if self.emergency_phase == 1:
#if we're falling
if self._log_stack[-1][1]['acc.z'] < 0.97:
#push the motors !
self._helper.cf.commander.send_setpoint(0,0,0,self._log_stack[-1][1]['stabilizer.thrust']+300)
else:
self.emergency_phase = 2
if self.emergency_phase == 2:
#if we're falling
if self._log_stack[-1][1]['acc.z'] > 0.97:
#lower the thrust slightly
self._helper.cf.commander.send_setpoint(0,0,0,self._log_stack[-1][1]['stabilizer.thrust']-100)
elif self._log_stack[-1][1]['acc.z'] < 0.92:
#push up a bit thrusts
self._helper.cf.commander.send_setpoint(0,0,0,self._log_stack[-1][1]['stabilizer.thrust']+100)
else:
#we land slowly but surely
pass
if self._log_stack[-1][1]['stabilizer.thrust'] < 20000:
self._helper.cf.commander.send_setpoint(0,0,0,0)
def _log_data_received(self, timestamp, data, logconf):
"""Callback from the log API when data arrives"""
#we stack the data that arrives
self._log_stack.append([timestamp, data])
self._emergency_treatment()
self.dataTextView.setText(repr(data))
self.i+=1
print("data" + '[%d][%s]: %s' % (timestamp, logconf.name, data))
def _param_updated(self, name, value):
"""Callback when the registered parameter get's updated"""
logger.debug("Updated {0} to {1}".format(name, value))
if not self._holdAltitudeBtn.isEnabled():
self._holdAltitudeBtn.setEnabled(True)
self._holdAltitudeBtn.setChecked(eval(str(value)))
def set_alt_hold(self):
self.helper.cf.param.set_value("flightmode.althold", str(enabled))
