I saw this
https://github.com/bitcraze/crazyflie-l ... equence.py
but i don't know how to enable it, and let the crazyflie fly in the air.
Anyone know this?
Thanks.
[sovled]How to use the automousSequence
Re: How to use the automousSequence
This example will work if the Crazyflie know its position, like in the loco positioning system. There is more doc on how to use it on the wiki: https://wiki.bitcraze.io/doc:lps:index# ... ithout_ros
Thanks for your replay.I have looked this doc before, but now I don't know how to run the script.Can you give me a example to run this script.arnaud wrote:Hi,
Assuming you have the Crazyflie lib and client installed in your system you will just have to run it with "python3 automousSequence.py" from the console.
