import sys
sys.path.append("../lib")
import cflib.crtp
import time
print("Scanning interfaces for Crazyflies...")
if True:
# Create a Crazyflie object without specifying any cache dirs
cf = Crazyflie()
def handle_connected(link_uri):
print("Connected to %s" % link_uri)
print("Sending thrust 45000")
cf.commander.send_setpoint(0, 0, 0, 45000)
#time.sleep(0.75)
print("Stopping thrust; hovering")
cf.commander.send_setpoint(0, 0, 0, 32767)
cf.param.set_value("flightmode.althold", "True")
def close_link():
print('Closing')
cf.commander.send_setpoint(0, 0, 0, 0)
time.sleep(0.1)
cf.close_link()
# Connect some callbacks from the Crazyflie API
cf.connected.add_callback(handle_connected)
link_uri = "radio://0/80/250K"
print("Connecting to %s" % link_uri)
# Try to connect to the Crazyflie
cf.open_link(link_uri)
# Variable used to keep main loop occupied until disconnect
is_connected = True
try:
while True:
time.sleep(1)
except KeyboardInterrupt:
close_link()
else:
print("No Crazyflies found, cannot run example")
