I intend to use the parameters from the new lps param group so I cloned the source code from master firmware, compiled and flashed the firmware into my CF2. But after doing that when running the ramp.py and basiclog.py I got no answer from CF2. In the first case nothing happened and in the second case all the angles were shown as 0.
Going back to the 2016.02 release firmware the CF2 began working fine again.
I use a Crazyradio PA running the 99.54 version of the firmware.
I client is also up to date.
Can anyone help me to fix this?
