I'm using the eclipse on the bitcraze virtual machine to flash the firmware to the crazyflie. I've been following the directions from the bitcraze wiki: https://wiki.bitcraze.io/projects:virtu ... mware-win7 (See the last section)
But I can't seem to find the "make" pane anywhere on eclipse. Here is a photo.
Bitcraze VM Eclipse CF2 Firmware
Re: Bitcraze VM Eclipse CF2 Firmware
The make section is the green round button in the right. This has moved in the last revision of eclipse. Can i use this screenshot in the wiki for better documentation?
Ok thanks. Yes you can use this in the wiki.
Thanks, Actually I just added a waning since we have an up to date tutorial with pictures on the website.
