Secondary or trainer input option
SuperRoach
Post by SuperRoach »
Typically with traditonal radio controls, they will let a slave device connect to it, so the trainer can help someone out learning.
With that in mind, is it possible to load more than one config at a time, or multiple device support possible with the cfclient software?
allynbauer
Re: Secondary or trainer input option
Post by allynbauer »
It is possible to do so, but adding that functionality would require a pretty significant refactor of the existing input handling code. Best to make a new issue unless you want to dig into the code yourself.
