The meaning of thrust = 60000
Peter
Post by Peter »
Hi gays, i want to know what does mean thrust =60000.
it means 60000 rpm ?
CrazyGuy
Re: The meaning of thrust = 60000
Post by CrazyGuy »
The thrust is a 16 bit unsigned value where 65536 means 100% thrust and 0 means 0%. The relation between ratio and thrust has been tested there: https://wiki.bitcraze.io/misc:investigations:thrust
Since a little while we now have battery compensated thrust based on this investigation, now the thust is more or less independant of the battery voltage (ie. an of-the-box crazyflie will take off and hover at about 50% thrust for the entire battery life).
Peter
Post by Peter »
