flight automation
Posted: Tue Mar 24, 2015 4:56 am
hi
i am a student and i want to make crazyflie to fly in the air without any controller and the problem i am getting that i am not able to figure out what variables in the firmware used for what and how to define pins in the coding part and in which .c file in order to add some different sensors to the crazyflie and also want to know can i control the flight movement through logs and parameters or i need to write code for that in the stabilizer.c
and also can you tell me brief about other .c files and the variables used with logs and parameters
thank you
thank you
