crazyflie-firmware
x893
crazyflie-firmware
Post by x893 »
i compile crazyflie-firmware under Keil (ARMCC) with O1 optimization and see:
Program Size: Code=39060 RO-data=1540 RW-data=968 ZI-data=16736
[/b]
if i compile under arm-none-eabi-gcc.exe 4.6
   text    data     bss     dec     hex filename
  77916     460   16344   94720   17200 cflie.elf
[/b]
What compiler you use to build firmware ?
Re: crazyflie-firmware
We use GNU Tools for ARM Embedded Processors that can be fond here: https://launchpad.net/gcc-arm-embedded/+download
As said Macus we are using arm-none-eabi-gcc 4.7 maintained by ARM.
For the code size it becomes a bit better with -Os (Setting DEBUG=0 in config.mk, good to use if no jtag debug is planned):
  47700	    400	  16336	  64436	   fbb4	cflie.elf
x893
Post by x893 »
OK - i try with your recomendations
Göran
Post by Göran »
I compiled the firmware under OSX using gcc-arm-none-eabi-4_7 (MacOSX version) from ARM.
  79596	    460	  16344	  96400	  17890	cflie.elf
I downloaded your code as an archive (rather than installing hg/Mercurial) so the version.c was messed up and i hand patched it to compile. No other problem with external library dependancies, very simple to compile!
Will you switch to the MARG/AHRS implementation for stabilisation including the magnetometer in the 10DOF version of HW? Seems pretty strait forward to drop in that code. Is the pressure sensor readings combined with the magnetometer?
We have quickly been experimenting with a MARG filter but it requires the magnetometer to be calibrated since it is very offset by the motor magnet fields. Other then that it should be pretty straight forward as the Madgwick's and Mayhony's algorithms exist in MARG versions as well. However making a calibration routine is what takes time. Maybe we can make use of Fabio's work (FreeIMU).
Göran
Post by Göran »
tobias wrote:We have quickly been experimenting with a MARG filter but it requires the magnetometer to be calibrated since it is very offset by the motor magnet fields. Other then that it should be pretty straight forward as the Madgwick's and Mayhony's algorithms exist in MARG versions as well. However making a calibration routine is what takes time. Maybe we can make use of Fabio's work (FreeIMU).
R.I.P Fabio.
Im new to embedded stuff and I2c bus, how can you programmatically know if the magnetometer is onboard or not? From the schematics is looks like its connected on the MCU6050 aux port, so the readings will be delivered together with the Acc and Gyro readings?
The MPU6050 can put the i2c aux in passthrough so that it looks like they are on the same bus.
eman
Post by eman »
Could you post your Crazyflie firmware code in Keil ARM for me?
Thank you.
DerShu
Post by DerShu »
eman wrote:Could you post your Crazyflie firmware code in Keil ARM for me?
Thank you.
I would really like to get a Keil Crazyflie project file that works with the project structure used by the Crazyflie code too!
I have been trying to get a good compile working with Keil. :oops:
