During swarming, some crazyflies crash or unbalanced at the same time.
t.yoneda
Post by t.yoneda »
Hello!
I test 10 crazyflies swarming.
when 10 crazyflie are on swarming, some crazyflie crash or lose balance at the same time.
the timing of these event is random.
movies: (Google Drive)
movie1
movie2
movie3
this is the flight area environment.
the red area is the flight range of the crashed or unbalanced crazyflies
my questions
1. why did the crash and unbalance happen at the same time?
2. How can I know the cause of the problem?
Regards,
Re: During swarming, some crazyflies crash or unbalanced at the same time.
Post by kimberly »
Thanks for the videos!
It is a bit difficult to see where these crashes come from... It can be perhaps due to bad batteries, wind of the propellers of the other drones or perhaps you are flying to close to the top of the lighthouse basestations. But let's figure it out!
Here are some questions.
- Do you know which controller are you using? PID or Mellinger?
- The bright open door in the back, is that direct sunlight?
- Are the crazyflies running on the latest release of the firmware?
- What are you using to control them? A pythonscript, crazyswarm or are you using the app layer.
t.yoneda
Post by t.yoneda »
Hi, kimberly!
Thanks for reply.
The output of crazyradio-pa is set to the lowest setting (P_M18DBM)
1. I use high_level_commander and upload polynomial trajectory.
2. The video was taken in 15:00~19:00. it is sunlight and fluorescent light.
3. all crazyflies and lighthouse decks are flushed the 2021.03 firmware from cfclient
4. I used crazyswarm of crazyflie-lib-python to control them
