[SOLVED] battery wont charge
PapaWhiskey
Post by PapaWhiskey » Mon Sep 23, 2013 4:43 pm
I received my Crazyflie directly from you end of last week, when going through the initial testing I notice that the battery shipped with the fly does not charge.
I'm assuming the way to charge it is to plug it into the fly and connect USB.
Has it been on the shelf for a long time?
Peter
marcus
Re: battey wont charge
Post by marcus » Tue Sep 24, 2013 5:27 am
Yes, you charge it using the USB. Is the blue LED lit when you connect the USB? Is the green LED blinking when you connect the USB? The correct LED sequences are noted on the wiki.
PapaWhiskey
Post by PapaWhiskey » Tue Sep 24, 2013 4:58 pm
Ok, there's a button ... I skipped the 'Introduction' and dove inte 'Assembly' continuing into 'Bootloader' .... I guess I should do a little bit of RTFM ... sorry.
