Library of crazyflie in ROS documents
RyanMco
Post by RyanMco »
Hi guys, Im using python script test_high_level.py and in this script there's
import crazyflie
but in my PC it shows me that the library crazyflie isn't found .. how do I download crazyflie library on Ubunto 18? thanks
RyanMco
Re: Library of crazyflie in ROS documents
Post by RyanMco »
when I do python test_high_level.py it tells me that
import crazyflie library isn't found .. although I downloaded crazyflie_ros
how do I update crazyflie library to crazyflie_ros?
whoenig
Post by whoenig »
This refers to the helper library in https://github.com/whoenig/crazyflie_ro ... azyflie.py. It should be found automatically, as long as you run python with crazyflie_ros/crazyflie_demo/scripts as your current working directory.
