How to read barometer values on Python API?
Posted: Fri Nov 08, 2019 2:02 pm
by dasmehdix
Hi, I have crazyflie 2.0.I can use Python API as a beginner.At the example of (this)https://github.com/bitcraze/crazyflie-l ... logSync.py,I understand that I can recieve, roll, pitch and yaw parameters, but I also want to achieve the barometer values interval on time or it can be a converted value as distance on z-axis.How can I recieve these values?
I understand that I have to use "LogConfig" and "LogConfig.add_parameters("etc")" but I do not know the name of parameter to recieve barometer.
 lg_stab =LogConfig(name='ranges',period_in_ms=100)
 lg_stab.add_variable('ranges.zrange','uint16_t')
Basicly, How can I recieve the barometer data in Python API?
Thanks.
Note: I search about this topic, but I couldn't find any solution.Sorry if duplicated.
Re: How to read barometer values on Python API?
Posted: Tue Nov 12, 2019 10:25 am
by arnaud
You need to log either the variable "baro.asl" if you are interested in 'Above Sea Level' measurement in meter or "baro.pressure" if you want to raw pressure measurement.
The best if you want to see what log variable is available is to connect with the Crazyflie client and to look at the "Log TOC" tab, it lists all variable and the name usually allows to find out if what you are looking for is already available as a log variable. The client can also plot log variables which is useful to see what to expect when using the values.
