Cannot fit three boards
Posted: Sat Aug 31, 2019 11:57 am
by r0b0tn1k
Hey guys!
I tried setting up the ranger deck, but it seems there's no space vertically?
I am looking at the setup guides, and I'm using the long pins, but there's just no room, the deck barely sticks on one side in the pins.
I'm using this setup: Image, but there's no room.
Photos:
Please help a brother out.
Re: Cannot fit three boards
Posted: Fri Sep 20, 2019 9:19 pm
by Lombazombie
Hey r0b0tn1k,
Is there a deck on the bottom? It looks like its being stopped from going all the way up.
We actually ran into this issue as well since we had a custom deck that was a bit bigger. What we had to end up doing was removing that black part from the pins and individually pushing them through. I can probably post pictures later tomorrow or Monday.
Thanks.
Posted: Mon Sep 23, 2019 12:31 pm
by tobias
If you mount the battery the other way around so the usb connector is not in the way?
Posted: Tue Sep 24, 2019 11:59 am
by r0b0tn1k
Hi Lombazombie,
The bottom deck is an optiflow deck.
I had solved my problem like this:
I wanted to solder the two long connectors, but I am bad at it and threw two of them in the garbage.
So next I put the multiranger on a new set of long connectors, and 3d printed a box just a bit taller than the battery. I used it to basically guide the multiranger deck on the long connectors to the remainder of the decks. Then very slowly I soldered the two connectors together.
Even with that, its a bit crooked, but at least it works.
I suggest you guys find some pin-connector-thingie that you sell, so we dont have to resort to soldering.
Here's the end result.
Hey r0b0tn1k,
Thanks.
Posted: Tue Sep 24, 2019 12:02 pm
by r0b0tn1k
Than the cable doesnt reach... :(
Posted: Tue Sep 24, 2019 12:36 pm
by tobias
If you want three boars the solution r0b0tn1k showed is pretty good. Else what if you do like this?
