multiple crazyflie ranging example with 1 crazyradio
Posted: Tue Jan 22, 2019 1:12 pm
Is there any guide on how to use more than 1 crazyflie in the Stem ranging bundle example using 1 Crazy radio PA. I understand that probably additional URIs are needed to be added with different addresses but would be helpful if someone has done this and can explain the steps in order to run the same example with ranging sensor.
Thanks
Naveed
Thanks
Naveed
