[SOLVED] flowdeck2 problem
Hi all,
I just purchased the new flowdeckv2, however my crazyflie2 has trouble reading it out. It recognize the deck but I get the following readout in the console, along with the 3 times fast blink of M1:
SYS: Build 187:47ee696b2d3c (2018.01.1-187) CLEAN
SYS: I am 0x30343631303747130031003A and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 16 drivers
DECK_CORE: 1 deck enumerated
ZR2: Z-down sensor [FAIL]
MPU9250 I2C connection [OK].
AK8963 I2C connection [OK].
LPS25H I2C connection [OK].
ESTIMATOR: Using estimator 2
CONTROLLER: Using controller 1
EEPROM: I2C connection [FAIL].
AK8963: Self test [OK].
DECK_CORE: Deck 0 test [FAIL].
It seems that the vl53l1x fails to init for some reason. Anybody has the same problem?
With the latest master of crazyflie-firmware github repository, I tried it on two different CF2's, with two different flowdeck v2's. I also tried the flowdeck v1, however that still works with the current master.
Re: flowdeck2 problem
I was able to sort of trace the problem down to the I2C communication. Unfortunately my gdb debugging on the stm doesn't work so I can't really efficiently debug it any further.
However, the following line is quite interesting:
If I remove the flowdeckv2, or replace it with a flowdeckv1, it turns into:
EEPROM: I2C connection [OK].
Maybe that could hint that the flowdeckv2 is interfering with the I2C communication of the eeprom memory module in some way?
Shushuai
Post by Shushuai »
I also have the same problem. Even if I used the firmware crazyflie-2018.10.zip which should support Flow V2 deck. The firmware link is https://github.com/bitcraze/crazyflie-r ... ag/2018.10
Probably it is the i2c communication conflict between VL53L1x and onboard EEPROM.
Hi all!
We found a production problem with the first Flow v2 decks. The test rig have damaged the connector. This is possible to fix with the tip off a needle and if that doesn't work send us a support mail and we will arrange with replacements (that will take time though :oops: )
Fixing steps.
  1. Get a small needle (around 0.5mm in diameter)
  2. Start with one pin and push the needle though the contact. If there is no or minimal friction it needs to be fixed.
  3. Use the tip of the needle to get behind the inner golden "tongue" and gently bend it out. There are two tongues, front and back, that can be adjusted.
  4. Test the contact again. If it was bent out to much test from the bottom to not risking over-bending the tongue the wrong way. If it was bent to little, redo it.
  5. Repeat this for all contacts. Takes around 5min when you got the hang of it.
toni
Post by toni »
Hello Tobias,
I have found some problems while hovering using flow 2 deck. When using v1 crazyflie hovers quite good. However when doing the same task with flow v2 there is big drift (drone moves more than 20 cm from when it started).
Do you know if this is related with those productions issues, or there is another problem in this case ? Is possible to fix this problem?
Thanks for your help, best regards
Does it drift just during take-off or also while hovering in the air? The difference between the v1 and v2 is the distance sensor and they might behave a bit differently while close to the ground. Maybe this is what's causing it.
toni
Post by toni »
It drifts both during taking off, and while hovering in the air once it arrives to the desired height (It goes to the correct height). What's more if I leave it hovering more than 20 s, crazyflie crash due to drift pushing it towards the wall.
Can this behaviour be corrected?
Sounds like the sensor isn't working as it should. Could you please send an email to support (at) bitcraze.io and we will help you out.
Just to give an conclusion to this forum thread (sorry for the late update). I got a replacement of the flowdeck v2.0 and they were all working fine. It was indeed the connector, and the errors I noticed was just because it was not connecting properly :)
