[SOLVED] No bluetooth connection after flashing NRF
alex
Post by alex » Thu Feb 18, 2016 10:44 pm
I updated the NRF firmware on my CF 2.0 with the make target cload BLE=0. It worked fine, but since then, my android phone isn't able to connect to the CF via bluetooth (using the CF app, of course). Seems obvious due to the BLE flag set to 0, but even after flashing with BLE=1 the bluetooth connection attempt always times out.
I followed this guide: viewtopic.php?f=5&t=1678&p=8688&hilit=flash+nrf#p8806
Before flashing the NRF the bluetooth connection was alright, so what am I missing?
-alex
chad
Re: No bluetooth connection after flashing NRF
Post by chad » Fri Feb 19, 2016 8:18 pm
Hi alex,
I'm a little confused...
Did you run:
make BLE=0 all
and then you ran:
make cload BLE=1
'make cload' only flashes the NRF (no compilation) so I believe that passing BLE=1 to this make target is meaningless.
If you try to clean the project, then make it with no arguments (which is the same as saying BLE=1), then cload, do you still have an issue connecting? I just tried that and it worked OK for me.
make clean
make all
make cload
Crazyflier - my CF journal...
Raspberry Pi Ground Control.
Mac OS X Dev Environment.
alex
Post by alex » Sat Feb 20, 2016 1:41 pm
Ok, obviously I didn't know what exactly I was doing, thanks for bringing me on track.
make clean
make all
make cload
This did the job!
Can you recommend some basic reading about make files and related stuff in general?
-alex
chad
Post by chad » Sun Feb 21, 2016 7:50 pm
alex wrote:This did the job!
-alex
Awesome! Glad you got it fixed!! :)
I'm not sure exactly what you're looking for. I read the actual Makefiles themselves and the READMEs in the repository. But I also have 15+ years of software build engineering experience. :oops:
If you're looking for a tutorial on 'make' and Makefiles, have a look at these M.I.T. OpenCourseware lecture notes but keep in mind it is very basic.
alex
Post by alex » Sun Feb 21, 2016 9:13 pm
chad wrote: I'm not sure exactly what you're looking for. I read the actual Makefiles themselves and the READMEs in the repository. But I also have 15+ years of software build engineering experience. :oops:
Exactly what I was looking for, thanks again, chad.
chad
Re: [SOLVED] No bluetooth connection after flashing NRF
Post by chad » Sun Feb 21, 2016 10:08 pm
My pleasure! Glad to have you back on the forum alex! :)
