Hi
i'm a newbee here, Recently I have installed Crazyflie PC client for Windows XP and 7,
Gives the following error after running.
Where is the problem?
My OS: Windows XP 32 bit , Windows 7 64 bit.
[SOLVED] Crazyflie PC client not RUN
Crazyflie 2.0 + Crazyradio PA + Debug Adapter and LED Deck.
Re: Crazyflie PC client not RUN
What is the solution ?
Do you have two machines and it happens on both of them?
How did you install the PC client?
I didn't see much by looking in the stack trace - it could be an issue with a Qt version mismatch of some sort.
Yes.whoenig wrote:Do you have two machines and it happens on both of them?
I have the same problem on Windows 7 64bit.
Do Crazyradio must be connected at run time ?
I'm confused
The problem was solved.
I've installed new windows, I did not install any software.
Crazyflie PC client conflict with a software, But I do not know
