Stabilizer never completes calibration, appears to have started after changing radio channel
super_flie_guy
Post by super_flie_guy »
Hey all, I'm pretty new to the Crazyflie(2.1) platform so perhaps this is just user error... but I've hit a bit of a conundrum and tried everything I could think to do with the python client, logging the results over crazy radio (all zeroes from the stabilizer) and leaving them on the stablest surface I could find until they could calibrate. No matter what I do, the problem drones always report the following output to console in the python client.
SYS: Production release 2020.06
SYS: I am 0x20383347344D5008002D0057 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_CORE: 0 deck(s) found
EEPROM: I2C connection [OK].
SYS: Free heap: 13216 bytes
With it just ending there and never completing the process as it normally would (and does) for the other drones I acquired, which I was able to compare it to.
SYS: I am 0x20383347344D50070039004A and I have 1024KB of flash!
STAB: Ready to fly.
I speculated that it might be a some sort of hardware error, but thinking back it seems to have occurred the same way to two of my drones (which I then learned not to try on the others): I changed the radio channel from the default 80 to some other one following the upload of the newest firmware(https://github.com/bitcraze/crazyflie-r ... 020.06.zip) via the boot loader, which immediately caused them to go from sending telemetry data while connected to none at all. Switching back to the default channel unfortunately did not restore telemetry data, which prompted me to start trying to figure out why and then clued me into the stabilizer not calibrating. I'm not really certain what I could have done to bust the stabilizer otherwise, or how to return them to their original out of the box state (tried the python EEPROM script, no luck) so any advice you all could provide on what might have gone wrong or what I might be overlooking in the crazyflie that's accessible by Python would be super appreciated.
Re: Stabilizer never completes calibration, appears to have started after changing radio channel
Post by kimberly »
It is odd since the IMU test passed according to the debugprints....
Have you tried looking at the raw IMU values in the plotter of the cfclient?
super_flie_guy
kimberly wrote: Mon Aug 24, 2020 9:45 am Hi!
Hey there, sorry for not responding quicker, The plotter tab only provides the same output for both the working and non working drones when I connect them to the client (see the attached). It might be different for the one that can fly once it gets airborne, but I didn't test that since the other can't fly right now anyway. On the other hand the terminal logs for the cf client seem to show a slight difference between the drones. Here is the output of the working version vs the never stabilizing one. I can see that the extra bit refers to the loco deck (which I do not have, and never tried to configure) but is it possible I somehow put it into a loco deck seeking mode with the boot loader? I did not have the loco position tab open when connecting to the bugged out drone, and also didn't when I first flashed the firmware, but again any insights you all could provided would be super appreciated.
Normal output
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/80/2M]
INFO:cflib.crazyflie:We are connected[radio://0/80/2M], request connection setup
INFO:cflib.crazyflie:Callback->Connected to [radio://0/80/2M]
INFO:cflib.crazyflie.platformservice:Procotol version: 4
INFO:cflib.crazyflie.mem:9 memories found
INFO:cflib.crazyflie:Memories finished updating
INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/80/2M]
INFO:cfclient.utils.logconfigreader:Parsing [stabilizer.json]
QObject::connect: Cannot queue arguments of type 'QList<QPersistentModelIndex>'
(Make sure 'QList<QPersistentModelIndex>' is registered using qRegisterMetaType().)
INFO:cfclient.ui.tabs.LEDTab:Memory: id=1, type=LED driver, size=24
INFO:cfclient.ui.tabs.locopositioning_tab:Crazyflie connected to radio://0/80/2M
INFO:cfclient.ui.tabs.locopositioning_tab:Requesting loco deck parameter
INFO:cfclient.ui.main:LED write done callback
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.BMP388]: 0
INFO:cflib.crazyflie.log:Have successfully started logging for id=1
INFO:cflib.crazyflie.log:Have successfully started logging for id=3
INFO:cflib.crazyflie.log:Have successfully started logging for id=4
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.HMC5883L]: 0
INFO:cflib.crazyflie.log:Have successfully started logging for id=5
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.MS5611]: 0
Never stabilizes output
INFO:cflib.crazyflie.mem:8 memories found
INFO:cfclient.ui.tabs.locopositioning_tab:No Loco deck installed
QObject::connect: Cannot queue arguments of type 'QVector<int>'
(Make sure 'QVector<int>' is registered using qRegisterMetaType().)
INFO:cfclient.ui.tabs.FlightTab:Changed effect to 0
Post by kimberly »
Unfortunately the cfclient terminal output will not give that much useful information, only the 'console tab' is supposed to do that.
I don't see any value plotted in the plotter tab though. Please checkout the guide. The drones don't need to be flying for this.
You can check also if you are getting the same problem if you connect the crazyflie through microUSB to your computer
dominik.natter
Post by dominik.natter »
Hey everyone,
I felt like my problem fits best into this post. I have 10 Crazyflies and 9 of them work fine. One, however, does not ramp its motors (neither when running examples/ramp.py nor when connecting via my smartphone). So I started to investigate.
I saw that the M1 LED blinks only red every 2 seconds, thus I checked the console log for a potentially missing calibration. Judging from the log the IMU is fine (i.e., there's no IMU-related error), but the calibration still never takes place. This is the exact same behavior as in @super_file_guy's case. Here's my log (I removed all decks to be sure it's not a problem of the decks):
SYS: Production release 2020.04
SYS: I am 0x20303743575350170020004E and I have 1024KB of flash!
So from what I can tell the line
STAB: Ready to fly.
is missing.
I further used the cfclient to create a log block with the IMU (accelerometer and gyro), which I then printed in the plotter. For a working Crazyflie this outputs a nice graph like here,
but for the problematic Crazyflie the sensor values simply do not change at all as seen here
Did a solution to this problem arise in the last few months? Please let me know if there's anything else I shall test with the problematic Crazyflie.
Thanks a lot,
Dominik
Sounds like a problem with the BMI088 IMU and that is unable to calibrate. Can you check the logging varables:
LOG_GROUP_START(gyro)
LOG_ADD(LOG_INT16, xRaw, &gyroRaw.x)
LOG_ADD(LOG_INT16, yRaw, &gyroRaw.y)
LOG_ADD(LOG_INT16, zRaw, &gyroRaw.z)
LOG_ADD(LOG_FLOAT, xVariance, &gyroBiasRunning.variance.x)
LOG_ADD(LOG_FLOAT, yVariance, &gyroBiasRunning.variance.y)
LOG_ADD(LOG_FLOAT, zVariance, &gyroBiasRunning.variance.z)
LOG_GROUP_STOP(gyro)
These should output data even though it is not calibrated. Check especially the variances. They all need to go below 10000 for the gyro to calibrate.
dominik.natter
Hi Tobias,
thanks for the quick reply. Your conjecture was correct: the variances are pretty high as seen here.
For the sake of completeness I also tracked the raw gyro values and rotated the Crazyflie around all 3 axes (first roll, then pitch, then yaw). The motion is measured by the gyro indeed (I cannot give a statement on whether the values are correct or not though).
Now we know the culprit. I wonder is there also a fix for this or is it simply malfunctioning hardware that we have to live with?
Furthermore, as a suggestion from a Crazyflie-newcomer: if there's such a fixed threshold (10,000) implemented already would it be possible to tell the user in this case something like "waiting for gyro variances to go below the threshold of 10,000"? Maybe that could help to find out the problem more quickly.
Post by kristoffer »
Hi Dominik!
It looks like your IMU is broken, send us an email at support@bitcraze.io and we will handle it there.
- Kristoffer
dominik.natter
Hi Kristoffer,
thanks a lot for your help! I have sent you guys an email.
Best,
Dominik
