Following Instruction #2 on web site
redtank
Post by redtank »
While following instruction #2: 2. Attach the Crazyradio to a computer and follow the installation instructions. When the Crazyradio is found and enumerated the red and green led will turn off. This is a good sign.
I've done this and it was a real PITA, but my Windows 7 accepted the radio dongle as a USB device, so case closed.
Anyways, my problem is that after Windows does it's thing, the red (blinking) and green led(s) are still lit. The instructions listed here: http://wiki.bitcraze.se/projects:crazyf ... s:assembly (item #2) state otherwise. So since the quadcopter pc board is still blinking red and had a green lcd working overtime, what can I do to correct the situation?
Thanks,
Cris
Re: Following Instruction #2 on web site
Is it the LED of the copter or the radio that stays still?
Best regards,
Arnaud
redtank
Post by redtank »
Arnaud,
It was in regards to the led's on the quadcopter. At the end of the day, all is well with led's still on depending on whether the bird is connected to my PC via the Client. Crazyflie works well but is a handfull. I've had to slow down the controls and trim it out to fly indoors. Over time I'll improve!
Thanks,
Cris
