Lh deck custom use
Posted: Thu Feb 04, 2021 10:39 pm
by Bostjan Nagode
Dear, as first, great work there..
I need to make a position device that would tracking it's position in area covered with vive v1 lighthouse. I have managed to do it with crazyflie. Amazed.. Im littlebit scare to ask, but i have a question about LH deck booting.
On crazyflie itself, i can see the Uart0 and uart1 tx sending serial data as described..
LH deck It has uart 0, uart 1 and i2c. In documentation i have seen some commands for leds and boot (0xbc), tried but with no sucess (probably those commands are active after boot.
Can maybie someone explain boot proces for LH deck in few words, how it can be done without Crazyflie deck?
Thanks in advance,
Bostjan Nagode
Re: Lh deck custom use
Posted: Fri Feb 05, 2021 12:44 am
by Bostjan Nagode
Sending 0x00 via I2C bus did the trick and now i can see the serial data output from LH deck.
Btw, commands for turning leds should work on uart? Sending 0x01 and led status doesnt do anything. I guess we are at 115200, n, 8 ,1. Any tip apreciated..
Thanks,
Bostjan Nagode
Posted: Fri Feb 05, 2021 9:16 pm
by Bostjan Nagode
Dear,
now Uart is alive and it is sending a bunch of data out of it. Is there anyone maybe that can assist anyhow in order to clarify what those numbers are? They are captured and are like in manual is written.
Sens:1 Chan:14 TimeS:16776960 Width:7681 Beamd:6 C:15597450
Sens:1 Chan:0 TimeS:16776960 Width:16419 Beamd:9 C:14483332
Sens:1 Chan:0 TimeS:10945023 Width:19813 Beamd:16711680 C:1927
Sens:0 Chan:0 TimeS:16776960 Width:32138 Beamd:8 C:14876453
Sens:1 Chan:0 TimeS:16776960 Width:30006 Beamd:9 C:14417808
Sens:1 Chan:0 TimeS:16776960 Width:33401 Beamd:12 C:13172627
Sens:1 Chan:0 TimeS:786684 Width:36800 Beamd:10067206 C:130966
Sens:0 Chan:0 TimeS:16776960 Width:0 Beamd:9 C:13959167
Sens:1 Chan:0 TimeS:258304 Width:46993 Beamd:11 C:4259743
Sens:0 Chan:0 TimeS:1908479 Width:17414 Beamd:10759424 C:122785
Sens:0 Chan:0 TimeS:16776960 Width:0 Beamd:6 C:15400959
Sens:1 Chan:0 TimeS:16776960 Width:57181 Beamd:9 C:14090152
Sens:1 Chan:0 TimeS:15073791 Width:60579 Beamd:16711680 C:1963
Sens:3 Chan:3 TimeS:16776960 Width:32175 Beamd:6 C:15465509
Sens:1 Chan:0 TimeS:16776960 Width:5233 Beamd:11 C:13237429
Sens:1 Chan:0 TimeS:16776960 Width:8638 Beamd:12 C:12976056
Sens:1 Chan:0 TimeS:516221 Width:12025 Beamd:12467274 C:131003
Sens:0 Chan:0 TimeS:16776960 Width:0 Beamd:11 C:13238271
Sens:1 Chan:0 TimeS:7471489 Width:22221 Beamd:16580608 C:3012
Sens:3 Chan:12 TimeS:9394 Width:65221 Beamd:16763156 C:13566374
Sens:0 Chan:0 TimeS:583678 Width:1024 Beamd:13467284 C:130875
Sens:0 Chan:0 TimeS:13238527 Width:0 Beamd:16711680 C:2303
Sens:1 Chan:6 TimeS:0 Width:32208 Beamd:1707006 C:13877029
Sens:3 Chan:13 TimeS:16776960 Width:339 Beamd:8 C:14417702
Sens:1 Chan:0 TimeS:16776960 Width:45990 Beamd:9 C:14417881
Sens:1 Chan:0 TimeS:16776960 Width:49384 Beamd:10 C:14024668
Sens:1 Chan:0 TimeS:8488714 Width:52777 Beamd:1670627 C:88799
Sens:1 Chan:0 TimeS:16776960 Width:65535 Beamd:11 C:13565697
Sens:1 Chan:0 TimeS:16776960 Width:62971 Beamd:10 C:13696232
Sens:1 Chan:0 TimeS:516988 Width:827 Beamd:15667329 C:131052
Sens:3 Chan:0 TimeS:722431 Width:385 Beamd:15877059 C:131071
Sens:0 Chan:0 TimeS:2042 Width:0 Beamd:0 C:696575
Sens:2 Chan:13 TimeS:11993439 Width:63159 Beamd:13041664 C:7678
Sens:0 Chan:3 TimeS:16776960 Width:65017 Beamd:8 C:14745583
Sens:1 Chan:0 TimeS:3025 Width:21198 Beamd:8192352 C:2032126
Sens:0 Chan:0 TimeS:5177855 Width:65280 Beamd:16711680 C:2559
Sens:3 Chan:2 TimeS:499849 Width:32004 Beamd:131071 C:22
Sens:3 Chan:15 TimeS:16776960 Width:1773 Beamd:9 C:14089216
Sens:1 Chan:0 TimeS:16776960 Width:38202 Beamd:10 C:14024461
Sens:1 Chan:0 TimeS:391549 Width:41583 Beamd:1290176 C:130832
Sens:3 Chan:0 TimeS:583806 Width:385 Beamd:1490171 C:131071
Sens:3 Chan:0 TimeS:65280 Width:385 Beamd:11 C:5636095
Sens:1 Chan:0 TimeS:6291967 Width:22353 Beamd:16711680 C:2331
Sens:1 Chan:15 TimeS:16776960 Width:32028 Beamd:8 C:14221078
Sens:1 Chan:0 TimeS:3017 Width:61973 Beamd:8201727 C:7012642
Sens:0 Chan:0 TimeS:7275007 Width:65280 Beamd:16711680 C:2047
Sens:2 Chan:6 TimeS:8488716 Width:32041 Beamd:687404 C:4179237
Sens:1 Chan:0 TimeS:16776960 Width:65535 Beamd:9 C:14483201
Sens:1 Chan:0 TimeS:16776960 Width:13433 Beamd:12 C:13172530
I have partially used your code to capture 12 bits..
for (int i = 0; i < UART_FRAME_LENGTH; i++) {
datau[i] = Uart_2.read();
if ((unsigned char)datau[i] == 0xff) {
syncCounter += 1;
memset(&frame_0, 0, sizeof(&frame_0));
bool isSyncFrame = (syncCounter == UART_FRAME_LENGTH);
frame_0.sensor = datau[0] & 0x03;
frame_0.channelFound = (datau[0] & 0x80) == 0;
frame_0.channel = (datau[0] >> 3) & 0x0f;
frame_0.slowbit = (datau[0] >> 2) & 0x01;
memcpy(&frame_0.width, &datau[1], 2);
memcpy(&frame_0.offset, &datau[3], 3);
memcpy(&frame_0.beamData, &datau[6], 3);
memcpy(&frame_0.timestamp, &datau[9], 3);
Thanks for your answer,
Bostjan Nagode
Posted: Mon Feb 08, 2021 10:50 am
by arnaud
That you had to send 0x00 is normal: the deck starts in bootloader mode and 0x00 is the command to start the firmware. The bootloader is documented there:
https://www.bitcraze.io/documentation/r ... -protocol/
To set the leds it should be enough to send "0x01 <LED_STAUS>" over the UART. For example sending "0x01 0x01" should blink the red led slowly.
As for the pulses, the screenshot you took documents what the different values are. The FPGA is acquiring lighthouse pulse timing and, for lighthouse v2, beam-data, identity and beam-time-offset. The meaning of the pulse if documented in many documents on the internet, we have not centralized the information in any of our doc yet. For lighthouse v1 this is a good repos:
https://github.com/nairol/LighthouseRed ... issions.md. For lighthouse V2 I explained a bit how it worked in this blog post:
https://www.bitcraze.io/2020/02/crazyfl ... thouse-v2/. The code in the Crazyflie should be mostly architecture independent so if can be used to decode the angles.
With both lighthouse V1 and V2 you will end up with a couple of angles per base-station. The crazyflie firmware repos contains some doc on how we use these angles to feed the kalman filter to achieved positioning:
https://www.bitcraze.io/documentation/r ... ighthouse/.
Posted: Mon Feb 08, 2021 8:13 pm
by Bostjan Nagode
Dear Arnaud,
thanks for answer, may i have just one more? In folder print_frame.py there is a function
def calculateAE(firstBeam, secondBeam):
, but i didnt see that is anywhere used. Is it possible to get somehow the source for that script that produce following result (in lighthouse fpga) :
$ ./tools/print_frame.py /dev/ttyUSB0
Waiting for sync ...
Found sync!
Sensor: 1 TS:5431ed Width: 13d Mode: None SyncTime: 0 BeamWord:128aa
Sensor: 0 TS:543291 Width: 141 Mode: 1(0) SyncTime: 28992 BeamWord:1a639
Sensor: 3 TS:5436c4 Width: 147 Mode: 1(0) SyncTime: 0 BeamWord:1f5dc
Sensor: 2 TS:543769 Width: 140 Mode: 1(0) SyncTime: 0 BeamWord:026f3
Sensor: 0 TS:56bcd9 Width: 120 Mode: None SyncTime: 0 BeamWord:1b903
Sensor: 1 TS:56be78 Width: 110 Mode: 1(0) SyncTime: 70714 BeamWord:175a5 Azimuth: -30.285°, Elevation: 4.576°
Sensor: 2 TS:56c094 Width: 113 Mode: 1(0) SyncTime: 0 BeamWord:05879
Sensor: 3 TS:56c21a Width: 12a Mode: 1(0) SyncTime: 0 BeamWord:1c094
Sensor: 1 TS:5b82f5 Width: 13f Mode: None SyncTime: 0 BeamWord:0debe
Sensor: 0 TS:5b8395 Width: 144 Mode: 1(1) SyncTime: 28992 BeamWord:11c42
Sensor: 3 TS:5b87c8 Width: 146 Mode: 1(1) SyncTime: 0 BeamWord:194c5
Sensor: 2 TS:5b8870 Width: 144 Mode: 1(1) SyncTime: 0 BeamWord:19e30
Sensor: 0 TS:5e0dcf Width: 118 Mode: None SyncTime: 0 BeamWord:19864
Sensor: 1 TS:5e0f71 Width: 119 Mode: 1(1) SyncTime: 70711 BeamWord:1511f Azimuth: -30.290°, Elevation: 4.568°
Sensor: 2 TS:5e1189 Width: 113 Mode: 1(1) SyncTime: 0 BeamWord:0d239
Sensor: 3 TS:5e1314 Width: 127 Mode: 1(1) SyncTime: 0 BeamWord:08c31
Posted: Tue Feb 09, 2021 9:32 am
by arnaud
If you look in the git history you can find the version of the script that produced that input:
https://github.com/bitcraze/lighthouse- ... t_frame.py
I would not necessarily trust that function though: we have had a lot of back-and-forth over time in the method used to estimate azimuth and elevation from the V2 beam. The formula in the code does not seems to math the last formula in this document which is not a good sign:
https://www.bitcraze.io/documentation/r ... onversion/
