...Bad Workspace and Sensor 3 Error
Posted: Thu Jun 11, 2020 9:09 pm
Hi I just flashed the lighthouse deck code to FPGA. Flashing was succceful however after I run test_frame.py the result is following format There is a 4 sensor on the board however only there of them shown in the output of the pyton script. I am just wondering any reason for that.
Also when I turn decodeV2_cf.py the result I got it
....bad workspace
....bad workspace
....bad workspace
Sensor: 2 TS:9dd19b Width: 102 Chan: None offset: 0 BeamWord:0bee0
Sensor: 1 TS:9dd5ae Width: 103 Chan: 1(1) offset: 41426 BeamWord:117f3
Sensor: 0 TS:9dd5cd Width: 102 Chan: 1(1) offset: 0 BeamWord:1f353
Sensor: 2 TS:a04be2 Width: 11d Chan: None offset: 0 BeamWord:1ef47
Sensor: 1 TS:a04c63 Width: 127 Chan: 1(1) offset: 81791 BeamWord:10a52
Sensor: 0 TS:a04e2a Width: 11d Chan: 1(1) offset: 0 BeamWord:09949
Sensor: 2 TS:a522b5 Width: 101 Chan: None offset: 0 BeamWord:1b5dd
Sensor: 1 TS:a526c2 Width: 107 Chan: 1(0) offset: 41429 BeamWord:13ccf
Sensor: 0 TS:a526ea Width: fb Chan: 1(0) offset: 0 BeamWord:13c67
Sensor: 2 TS:a79cc3 Width: 11d Chan: None offset: 0 BeamWord:189dd
Sensor: 1 TS:a79d45 Width: 124 Chan: 1(0) offset: 81781 BeamWord:07471
Sensor: 0 TS:a79f09 Width: 114 Chan: 1(0) offset: 0 BeamWord:127d7
....bad workspace
....bad workspace
....bad workspace
