I am currently trying to use the script provided in the Step-by-Step Guide. I copy-pasted the script and even if a deck is attached to the crazyflie, it still give back the "Deck is NOT attached" message. There is an existing topic about that issue, which suggested to change the int(value) but this did unfortunately not work for me.
Is there another solution?
Thanks in advance.
This is my current script:
import logging
import time
import cflib.crtp
from cflib.positioning.motion_commander import MotionCommander
URI = 'radio://0/80/2M/E7E7E7E7E7'
is_deck_attached = False
def param_deck_flow(name, value_str):
value = int(value_str)
print(value)
global is_deck_attached
if value:
is_deck_attached = True
print('Deck is attached!')
else:
print('Deck is NOT attached!')
if __name__ == '__main__':
scf.cf.param.add_update_callback(group="deck", name="bcFlow2",
cb=param_deck_flow)
time.sleep(1)
Can not detect deck when using the step-by-step: motion commander guide
Re: Can not detect deck when using the step-by-step: motion commander guide
The best way to check if a deck is detected by the Crazyflie is to use the python client.
Open the console tab and check if you can see a line saying something like "DECK_CORE: 1 deck(s) found"
You can also use the Parameters tab to check which deck that is detected. Find the "deck" group and expand it, you should see a list of all possible decks, for most of them the value should be 0, but hopefully the one for your deck should be 1.
Check the name of the parameter that is 1 and compare it to what you have in your script. The "name" on this line
should match the name of your deck. It is for instance possible that you have a Flow V1 deck (bcFlow) instead of a Flow V2 deck (bcFlow2)
scf.cf.param.add_update_callback(group="deck", name="bcFlow2", cb=param_deck_flow)
