[SOLVED] How to use python to restart the crazyflie?
aqqz
Post by aqqz »
Hi,i want to now how to use python to restart the crazyflie? i find cflib/utils/power_switch.py,but i don`t know how to use it. it always run error with crazyradio or crtp.
The following is my code:
import time
import cflib.crtp
from cflib.drivers.crazyradio import Crazyradio
from cflib.utils.power_switch import PowerSwitch
uri = 'radio://0/10/2M/E7E7E7E712'
if __name__ == '__main__':
    with SyncCrazyflie(uri,cf=Crazyflie(rw_cache='./cache')) as scf:
        cf = scf.cf
        ps = PowerSwitch(uri)
        ps.stm_power_down()
        time.sleep(3)
        ps.stm_power_up()
        time.sleep(3)
Re: How to use python to restart the crazyflie?
Have you looked at the reboot script in the crazyflie-firmware repo? That is doing exactly what you need.
aqqz
Post by aqqz »
I try to run as prompted,the following is my console output:
tz@ubuntu:~/crazyflie/crazyflie-firmware$ python3 tools/utils/reboot.py
Error: uri is missing
Usage: tools/utils/reboot.py uri
tz@ubuntu:~/crazyflie/crazyflie-firmware$ python3 tools/utils/reboot.py radio://0/10/2M/E7E7E7E710
  File "tools/utils/reboot.py", line 33, in <module>
    PowerSwitch(sys.argv[1]).stm_power_cycle()
  File "/home/tz/crazyflie/crazyflie-lib-python/cflib/utils/power_switch.py", line 63, in stm_power_cycle
    self.stm_power_down()
  File "/home/tz/crazyflie/crazyflie-lib-python/cflib/utils/power_switch.py", line 54, in stm_power_down
    self._send(self.BOOTLOADER_CMD_SYSOFF)
  File "/home/tz/crazyflie/crazyflie-lib-python/cflib/utils/power_switch.py", line 79, in _send
    if res.ack:
AttributeError: 'NoneType' object has no attribute 'ack'
Probably you have installed an older version of the cflib. Could you check that with:
pip freeze | grep cflib
And show the output here.
Also, which firmware version are you using on your crazyflie?
aqqz
Post by aqqz »
This is my console output, my firmware version is 2020.09
-e git+https://github.com/bitcraze/crazyflie-lib-python.git@0c70f88e407129cbe91281867cde9e165ab20e3c#egg=cflib
your cflib seems to be after this reboot functionality has been implemented....
So I tried it with firmware 2019.01 and cflib version 0.1.11 (which is the last version feature will work on). It works fine for me.
Could you reinstall the cflib to the latest release?:
pip3 install cflib==0.1.12.1
and then please try again. Also make sure that radio://0/10/2M/E7E7E7E710 is indeedd the right address for your crazyflie.
aqqz
Post by aqqz »
I reinstall my cflib and it prompt I have installed,the function can close crazyflie by not restart it and output error as I gived,i think the PA don`t receive the ack from crazyflie.my test environment is ubuntu 18.04.
aqqz
Post by aqqz »
I install the cflib on the Windows,now it works well,thank you i will close the topic.
