I want to write a new deck file with the name mlModelDeck. I created a mlModelDeck.c file under deck/driver/src folder as suggested by https://www.bitcraze.io/documentation/r ... ent/howto/. This file has following content:
#define DEBUG_MODULE "mlModelDeck"
#include "deck.h"
#include "system.h"
#include "commander.h"
#include "range.h" // get the 6axis distance measurements
#include "log.h"
#include "FreeRTOS.h"
#include "task.h"
#include "debug.h"
#include "sysload.h"
#include "sensors.h"
#define TRUE 1
#define FALSE 0
// These are my variable which will be used in this deck
static float inModelIMU[12] = {0};
static float inModelIMUOld[6] = {0};
static float outModelIMU[6] = {0};
static float errorModelIMU[6] = {0};
static void mlModelDeckTask()
// static setpoint_t setpoint;
systemWaitStart();
DEBUG_PRINT("FINISHED\n");
static sensorData_t sensorData;
uint32_t tick;
vTaskDelay(M2T(200));
while(1){
// tick = xTaskGetTickCount();
// This is where I will have following commented out code
// // Error model input preparation and evaluate
// // Saving old inputs
// if (((tick+5) % 20) < 5){
// for (int ii=0;ii<6;ii++){
// inModelIMUOld[ii] = inModelIMU[ii];
// inModelIMU[0] = sensorData.gyro.x/150;
// inModelIMU[1] = sensorData.gyro.y/150;
// inModelIMU[2] = sensorData.gyro.z/150;
// inModelIMU[3] = sensorData.acc.x/150;
// inModelIMU[4] = sensorData.acc.y/150;
// inModelIMU[5] = sensorData.acc.z/150;
// // Preparing whole input for model
// inModelIMU[6+ii] = inModelIMUOld[ii];
// outModelIMU[ii] = 0;
// // DEBUG_PRINT("tick: %d\n",tick);
// // DEBUG_PRINT("in_value: %f, %f, %f, %f, %f, %f\n", sensorData.gyro.x, sensorData.gyro.y, sensorData.gyro.z, sensorData.acc.x, sensorData.acc.y, sensorData.acc.z);
// // DEBUG_PRINT("in_value: %f, %f, %f, %f, %f, %f\n", inModelIMU[0], inModelIMU[1], inModelIMU[2], inModelIMU[3], inModelIMU[4], inModelIMU[5]);
// // get_inference_IMU(&inModelIMU,12/2,&outModelIMU);
// // vTaskDelay(M2T(100));
// DEBUG_PRINT("ou_value: %f, %f, %f, %f, %f, %f\n", outModelIMU[0], outModelIMU[1], outModelIMU[2], outModelIMU[3], outModelIMU[4], outModelIMU[5]);
// errorModelIMU[0] = outModelIMU[0] - sensorData.gyro.x/150;
// errorModelIMU[1] = outModelIMU[1] - sensorData.gyro.y/150;
// errorModelIMU[2] = outModelIMU[2] - sensorData.gyro.z/150;
// errorModelIMU[3] = outModelIMU[3] - sensorData.acc.x/150;
// errorModelIMU[4] = outModelIMU[4] - sensorData.acc.y/150;
// errorModelIMU[5] = outModelIMU[5] - sensorData.acc.z/150;
static void init() {
xTaskCreate(mlModelDeckTask, "mlModelDeckTask",
1000 /* Stack size in terms of WORDS (usually 4 bytes) */,
NULL, /*priority*/3, NULL);
static bool test() {
return true;
const DeckDriver mlModelDeck = {
.vid = 0,
.pid = 0,
.name = "mlModelDeck",
.usedGpio = 0, // FIXME: set the used pins
.init = init,
.test = test,
DECK_DRIVER(mlModelDeck);
LOG_GROUP_START(stabilizer)
LOG_ADD(LOG_FLOAT, errorModelIMU0, &errorModelIMU[0])
LOG_ADD(LOG_FLOAT, errorModelIMU1, &errorModelIMU[1])
LOG_ADD(LOG_FLOAT, errorModelIMU2, &errorModelIMU[2])
LOG_ADD(LOG_FLOAT, errorModelIMU3, &errorModelIMU[3])
LOG_ADD(LOG_FLOAT, errorModelIMU4, &errorModelIMU[4])
LOG_ADD(LOG_FLOAT, errorModelIMU5, &errorModelIMU[5])
LOG_GROUP_STOP(stabilizer)Code: Select all
PROJ_OBJ += mlModelDeck.oCode: Select all
CFLAGS += -DDECK_FORCE=mlModelDeckAfter compiling and flushing into the CF2.1, the client is showing 'self-test failure' (continuous red flash at M1 five times continuously).
Please advise what needs to be done to correct this. I went through some other deck program which seems to follow this structure.
