Query regarding Kalman filter update function.
imranmomtaz
Post by imranmomtaz »
I needed some help to understand which are the appropriate function for Kalman filter update when
1. I have lighthouse deck
2. I have flow v2 deck
3. I have both flow v2 and lighthouse deck
connected with CF. I can understand the main block is the
scalarUpdate
at
https://github.com/bitcraze/crazyflie-firmware/blob/master/src/modules/src/kalman_core.c#L225
. But I wanted to have better understanding regarding this. Thanks a lot.
Re: Query regarding Kalman filter update function.
There are a number of functions called in the kalman filter with various sensor data. Pointers to the implementation below.
When running in the default mode, sweep data is pushed to the estimator at https://github.com/bitcraze/crazyflie-f ... use.c#L235 and is handled in the kalman filter at https://github.com/bitcraze/crazyflie-f ... ore.c#L573
In the crossing beams mode position is pushed at https://github.com/bitcraze/crazyflie-f ... use.c#L213 and is handled in the kalman filter at https://github.com/bitcraze/crazyflie-f ... ore.c#L319
Yaw is pushed to the estimator at https://github.com/bitcraze/crazyflie-f ... use.c#L308 and is processed in the kalman filter https://github.com/bitcraze/crazyflie-f ... ore.c#L564
Assuming FlowV2 deck.
The optical flow information (x and y) is pushed to the estimator at https://github.com/bitcraze/crazyflie-f ... 1v2.c#L126 and is processed in the kalman filter at https://github.com/bitcraze/crazyflie-f ... ore.c#L469
The distance information is pushed at https://github.com/bitcraze/crazyflie-f ... er2.c#L142 and processed at https://github.com/bitcraze/crazyflie-f ... ore.c#L537
