Delete the bootmode
Posted: Wed Aug 07, 2019 12:46 am
by EduardodelaCruz
Hello everyone
I have a problem with crazyflie 2.0, I mistakenly deleted the crazyflie boot mode and I can't longer fly the crazyflie, can someone help me?
Thank you
Re: Delete the bootmode
Posted: Wed Aug 07, 2019 9:30 am
by tobias
Can you share some more info how you deleted it? Did you use a JTAG or was it just a "bad" flash? If so you can get into the bootloader again from a powered off state. Remove all power (battery, usb), hold button and connect battery, release when blue led starts blinking.
Posted: Wed Aug 07, 2019 3:58 pm
by EduardodelaCruz
Thank you for your response Tobias
I deleted the charging mode using the Keil uVison5 software, accidentally pressed delete and when I did it only the blue LED of the M2 was on and since then, this happened using the JTAG
Since then I have not been able to fly the crazyflie, I have tried to load from the Bitcraze VM with eclipse but I do not have good results
Thank you
Posted: Fri Aug 09, 2019 1:08 pm
by tobias
I guess you only changed the STM32F4? You can you try using the dfu method to restore the bootloader in the STM32F4 as described here.
Posted: Wed Aug 14, 2019 2:01 am
by EduardodelaCruz
Hi Tobias, thank you very much for answering.
Yes, I hope that only STM32F4 has changed, when I put the cfrazyflie in DFU mode and enter the VMbitcraze command window the following mistake appears (image)
The crazyflie2-stm-bootloader-1.0 folder is on my desktop, this file is necessary to run it in eclipse or what is its correct location?
