Crazyflie don't work
gabrielfvds
Post by gabrielfvds » Thu Jun 14, 2018 1:00 pm
Hello, my problem is:
I could not access crazyflie's bootloader mode, so I reinstalled the firmware using a ST LINK, now when I turn it on by pressing the ON / OFF button, only the M2 blue LED turns on.
Other problems:
Now I can not connect the crazyflie via Bluetooth
I use Linux, and VM
whoenig
Re: Crazyflie don't work
Post by whoenig » Thu Jun 14, 2018 4:34 pm
Can you still get to the bootloader by the following method?:
1. Disconnect CF (battery/USB)
2. Press the button and *at the same time* connect the CF to power (battery or USB); Keep the button pressed for 3 seconds.
3. After 3 seconds, if successful, the two blue LEDs should blink.
Note that 2. can be a two-person-job.
arix
Post by arix » Fri Jun 22, 2018 1:51 am
I think you use stlink maybe only flash nrf.bin. I remember you also need bootloader.bin and other bin, but i forget......
gabrielfvds
Post by gabrielfvds » Wed Jun 27, 2018 1:44 pm
Thank you all
I solved the problem doing the bootlooader DFU mode
I did
sudo dfu-util -d 0483:df11 -a 0 -s 0x08004000 -D cflie.bin
