I want to use another antenna.
violet
Post by violet »
Hello.
I'm using LPS and flow deck. My goal is to fly multiple drones without errors. (about 7~8 drones)
But at the start, 'too many pockets lost' occur often.
Sometimes, even if a connection is made, a different coordinate value or (0.5, 0.5, 0.0) is called.
I want the connection to always be good.
1. I'm using crazyradio with laptop and one channel per radio. Is the laptop's signal weak?
2. I think it's a hardware problem. I want to use another antenna because 2.4Ghz causes interference with WiFi. What should I do?
Re: I want to use another antenna.
Can you describe your setup in a little bit more details. I am mostly missing:
- How many Crazyradio are you using
- What channels/address are you using (do you use different address for different quad, how spaced are the channel)
- What are you using to control the Crazyflie, python script, ROS, something else?
