To use the 8520 motor
arix
Post by arix »
hello !
i have draw my own cf and i want to use 8520 motor to develop load . i need to change some code for that ? i have use the current code to control it but it can't work.
Thank you !
Re: To use the 8520 motor
There should have to be no code change but make sure the layout/board can handle the current as a 8520 uses a lot more current.
