if i want to build about crazyswarm, what needed?
NickCong
Post by NickCong » Sun Apr 15, 2018 11:20 am
Hi
i want to build crazyswarm about using 25 crazyflie,i read the http://act.usc.edu/publications/Preiss_ICRA2017.pdf and in the crazyswarm it using a VICON Vantage system with 24 cameras ,and in the http://crazyswarm.readthedocs.io/en/lat ... components,the components they used include 7.9mm reflective markers but not say where to buy the vicon vantage, how much about the vicon vantage if i want to build like crazyswarm? if it need cost too much, does i have another way to build crazyswarm?and does the lps can use to the crazyswarm instead the vicon?
whoenig
Re: if i want to build about crazyswarm, what needed?
Post by whoenig » Tue Apr 17, 2018 12:10 am
You can get a quote from VICON (https://vicon.com/) for your particular needs. We do support other mocap systems such as OptiTrack or Qualisys. Bitcraze LPS has not been tested with the Crazyswarm, yet.
NickCong
Post by NickCong » Sat Apr 21, 2018 11:43 am
ok,i see
thank you very much,
