a problem about VM
linlin2017
a problem about VM
Post by linlin2017 » Mon Nov 27, 2017 1:04 pm
Hi developers,
I have a question about the VM. I have installed the Oracle virtualBox and BitcrazeVM in my Windows PC, but when the VM is running, nothing is displayed except black background. Then I installed the Oracle virtualBox and BitcrazeVM in my Mac PC, the software installed in the VM can be displayed and I can use these softwares to build and download the projects. Today I bought a gamepad named Sony playstation 4 gamepad. I connected it to my Mac PC by a USB data cable, and I set VM following the tutorials. However, when I start the VM on my Mac PC, the VM can't work. The VM displayed a black background only, as it displayed on my Windows PC. I want to know the reason about these problems, and what should I do to solve them. Thank you. :)
Re: a problem about VM
Post by tobias » Tue Nov 28, 2017 9:25 am
Unfortunately we have started to see instability with virtualbox, so far mainly with its USB driver and this black screen is new to be. I suggest turning to a virtualbox community to get help with that problem.
What about trying to installing the tools natively instead?
linlin2017
Post by linlin2017 » Tue Nov 28, 2017 12:52 pm
I tried to install the tools natively on my Windows PC. Then my Playstation 4 could control the crazyflie 2.0, however, the link quality became bad and even the connection failed when I created a thrust by the Playstation 4. Do you have some suggestions to solve the problem? Thank you. :)
Post by arnaud » Wed Nov 29, 2017 9:27 am
You can try setting the radio link to 2Mbit/s and change the radio channel to find one that has less interferences.
linlin2017
Post by linlin2017 » Fri Dec 01, 2017 12:45 pm
Thank you. It became better when I set the radio link to 2Mbit/s. I also have a question that sometimes the link quality is well, but the client can't display the attitude information of crazyflie 2.0 and Playstation 4 can't control the crazyflie 2.0. And when I restart my PC, the problem can be solved sometimes.
Post by arnaud » Mon Dec 04, 2017 1:24 pm
Are you running the latest version of both client and Crazyflie? Older version has had locks at connection like the one you are describing, but it should now be solved.
linlin2017
Post by linlin2017 » Wed Dec 13, 2017 1:29 pm
Yes. I am running the latest version of both client and crazyflie firmware. The client version is 2017.06, and the crazyflie 2.0 firmware is updated by double-clicking the shortcut icon 'update all projects' in the VM.
Post by arnaud » Thu Dec 14, 2017 8:15 am
By running the "update all" script you are pulling the very latest version of the client. Though you are not updating the Crazyflie just by doing that. To update the Crazyflie you need to flash it using the client and the radio bootloader: https://www.bitcraze.io/getting-started ... #latest-fw
If you are on Windows, you can also try the Windows native client: https://github.com/bitcraze/crazyflie-c ... ag/2017.06. This would allow to verify if the problem comes from the VM or from something else.
