No fix with the new CF2. It was in open space, my other GPS devices (Garmin, Parrot) get a fix in a few seconds (12 satellites for Parrot). I tried to install the chip at a distance with wires. But I destroyed the chip when trying to remove it from deck.
Do you think that Titan 2 chip is better than Ubox? And what are the precise references and where could I buy one?
Thank you.
We have successfully used the Titan2 chip, I think the patch antenna is the key. uBlox have released a module worth trying too. Our issue though was to filter the voltage noise from the motors to below 50mV peek2peek the datasheet suggests.
