Disabling crash detection?
JarvisX
Post by JarvisX »
Hi, crazyfliers!
I have a quick question: is there a way to completely turn off the onboard crash detection and avoid the consequential motor shut-offs? I am using the crazyflie_ros stack with CrazyBolt. The crash detection seems to kick in whenever the robot is tilted more than a certain angle (90 degrees from nominal hover state in roll and/or pitch most likely,) and then shuts off the motors until a reset. Since we are experimenting with making a drone flipping, we need to avoid the crash detection from stopping with the motor actuation.
Best,
Jiawei
jonasdn
Re: Disabling crash detection?
Post by jonasdn »
Hi JarvisX!
Disabling the supervisor check is only possibly through modifying the CF2.1 firmware, there is no way to do itby sending a message to the Crazyflie.
The check is done in the supervisor module at line 120: https://github.com/bitcraze/crazyflie-f ... sor.c#L120
So you need to moedify the firmware and then flash the result, if you are unfamiliar with the process, check out this guide: https://www.bitcraze.io/documentation/t ... velopment/
Regards
Jonas
JarvisX
Post by JarvisX »
jonasdn wrote: Mon Jun 14, 2021 4:35 am Hi JarvisX!
Regards
Jonas
Thank you, Jonas! I will modify the firmware.
