Trajectory Generator
gabrielalima
Post by gabrielalima »
Using the package to generate trajectories and unload on the aircraft ... I did some tests. I understand that the trajectory is smoothed and the restrictions of the aircraft are considered.
But even so, I found the duration of the journey so long. A relatively short route that took longer than I thought ...
This is normal? I know the aircraft can fly faster than that ...
Thank you!
