Lighthouse with Big Quad Deck
thevoltmaster
Post by thevoltmaster » Fri Jul 12, 2019 2:17 pm
Hey, Is there any way to use the Lighthouse deck with the big quad deck? It seems from the matrix, it is incompatible, but I am wondering if there is a modification i could make to either deck to allow this functionality to work.
Thanks!
Re: Lighthouse with Big Quad Deck
Post by tobias » Thu Jul 18, 2019 9:05 am
We have not tested this yet but I think it should work. The TX1 and RX1 will be occupied by the Llighthouse deck but if you are not using the BQ-deck GPS port there should be no collision.
yonim
Post by yonim » Sun Oct 06, 2019 7:50 pm
Hi Tobias,
Have you tested position control on the CF2, using a GPS with the current Kalman filter?
If so, can you share a link?
Thank you, Yoni
Post by kimberly » Thu Jan 30, 2020 8:37 am
@Yoni
This is a different issue so please start a new forum thread with your question so it is easier for us to help you. Thanks!
