Determination of Measurement Noise STD
snyderthorst
Post by snyderthorst »
I am attempting to simulate the LPS system. I am currently attempting to add noise to the state estimate of the simulated robot, but am unsure of where to add it in to reliably simulate error. As I see it, I have two options:
1) Add the noise when the position of the robot is computed
2) Add the noise in the distance difference measurement
I am using an extended Kalman filter like that in the Crazyflie.
I was also wondering how the measurement noise standard deviation (https://github.com/bitcraze/crazyflie-f ... 2Tag.c#L43) was chosen?
Thank you!
Thomas
Re: Determination of Measurement Noise STD
The STD was measured as part of this paper:
Fusing ultra-wideband range measurements with accelerometers and rate gyroscopes for quadrocopter state estimation
Meuller et all (2015) ICRA (see here for pdf).
I believe they use a mocap system to measure it and they came to a 0.17 ns STD but that is now 0.15 ns for some reason (still pretty close)
If you would simulate the LPS system, I think you should go for option 2). The noise is supposed to be in the measurement anyway, so that will be closer to reality.
