big quad plus LPS
newcuriousstudent
big quad plus LPS
Post by newcuriousstudent »
Hello!
How would a big quad deck connect drone (the frame of the big drone) be to work with the LPS system aswell?
I have a big drone that I want to fly with the crazyflie big deck and the LPS at the same time.
The big quad I am using has a few parts that are metal (specifically the Power Distribution board and the Motors).
Would those be an issue for the LPS system (if it would work)
Thanks in advance!
Re: big quad plus LPS
With some modifications to the BigQuad deck it is possible. Read about it in the wiki here.
Getting a good reception could be tricky and ultimately it should be free space around the loco deck antenna. We have tested it with just a 5-10mm of free space from e.g. the bottom if it and still worked but I suspect it will have some degraded performance. I think the only way to really know would be to test.
