Thank you for seeing.
This is my first issue submission.
I need help on running Crazyfile-lib-python/example/position/initial_position.py.
I get the following error when I run initial_position.py.
Python is running version 3.7.7.
I have run Install cflib dependencies which is part of https://github.com/bitcraze/crazyflie-lib-python and I confirm that Python is working.
What should I do in the following cases?
best regards
Toji
[SOLVED] How to execute initial_position.py
Last edited by Jun-ichi Toji on Wed Jul 01, 2020 11:34 pm, edited 1 time in total.
Re: How to execute initial_position.py
Your error indicates that the python script is expecting the parameter 'kalman.initialYaw' to be in die parameter TOC. In the latest version of the code, it should be present, but it seems to be missing from the firmware of your crazyflie.
Have you updated the firmware of the crazyflie to the latest release? Here it will show you how to do this.
Thank you for your quick response.
My crazyflie could fly after I updated the firmware of it to the latest release
I really appreciate it!
Great it worked out!
